05-07-2008, 11:57 PM
Backdraft Damper??
Multi unit building. This access was above the tub in the bathroom. The label said "Access to Cape Backdraft Damper" What is this? My guess is to prevent backdraft to each unit from multi unit ducts branching into one central trunk? So no smoke can enter this unit in case of a fire / cooking odors, etc???
05-08-2008, 09:42 AM
Re: Backdraft Damper??
Superman would be proud. Thanks
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Damper stops & fesh air vent |
David Macy |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
7 |
01-07-2008 11:51 AM |
| Staining on Factory FP damper |
Jeff Eastman |
3 |
10-24-2007 01:53 PM |
| No damper on a Heatilator |
Scott Patterson |
2 |
08-07-2007 08:13 PM |
| Vent Damper |
neal lewis |
3 |
05-30-2007 05:39 PM |
| Staining on damper |
Jeff Eastman |
1 |
05-08-2007 07:30 AM |
Ad Management by
RedTyger
