You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
05-09-2008, 07:30 PM
Duct work
I'm running across this more often in new construction;duct installed directly into the back of the the plenum box they say this is ok,but I still have a problem with this any ideas???
05-09-2008, 08:14 PM
Re: Duct work
What is your problem specifically. Are you used to sheet metal?
Your photo looks like all the production builders in this area.
No problem with the principal other than there is more resistance with distribution box and flex ducts as opposed to sheet metal with smooth transitions and wye's.
Mr. Inspector.net, Inc.
Allen, Texas 75002
05-10-2008, 07:43 AM
Re: Duct work
Not sure of the problem either. I don't like lots of flex, especially straight off the unit. I've looked into this here. It's Ok if:
- combined snakes have sufficient CFM as to not choke the airflow
- if sleeve is metal not vinyl
- our Code has length limitations for snakes, vinyl and metal, especially in Res. Commercial code is different also
847/736-9975
Markus Keller
05-10-2008, 07:45 AM
Re: Duct work
Sorry, FOIL, not exactly metal
847/736-9975
Markus Keller
05-11-2008, 07:12 PM
Re: Duct work
Ok this is what I see is that there is no back pressure being present; that with that duct being installed directly into the back of the plenuim box the majority of air like water will take the path of least resistance; and will flow straight through the box and not out the side ducts with out this back pressure?  I may just be old school or am I missing something that I'm overlooking?? Still does not make scince to me.
05-11-2008, 07:18 PM
Re: Duct work
Randy,
Depends.
As in "depends on where/what that duct goes to.
It may go to another distribution box, in which case the entire duct would reach some static pressure level, depending upon the design of the system.
You don't want that going straight to a supply register, no.
05-11-2008, 07:23 PM
Re: Duct work
---- will take the path of least resistance; and will flow straight through the box and not out the side ducts .
Randy,
The End Duct is Smaller than the side ducts.
It Might have Choked Artie But it ain't gone'a choke Me!
Billy J. Stephens HI Service
05-11-2008, 08:06 PM
Re: Duct work
Well that is true about the size of the duct;still in my mind would never put it there;old dogs can maybe learn new tricks?!?!
05-11-2008, 09:07 PM
Re: Duct work
I think randy is correct. I have 2. 6" duct at the end of my plenum box and i get more pressure then from the side 4. 10" duct. If it hits the back and then finds its direction the pressure to each will be the same.
But then they may have a redirect in front of that end duct.
I think
Best
Ron
05-11-2008, 09:13 PM
Re: Duct work
The longer the run of the duct the more static pressure .
If the end vent is smaller and longer more force is needed than a larger and shorter run.
05-12-2008, 06:14 AM
Re: Duct work
I used to carry a regular electric tester. Then a couple years ago I upgraded to a "Fieldpiece" brand. Not only is it an electrical tester but it is built to accept many different attachment heads for different purposes. I have the AMP clamp, the carbon monoxide detector head and for this thread the CFM meter head.
When I'm especially suspicious of a system, I'll pull out the head and measure the CFM at various registers and grilles. It really comes in handy to prove a point. Also cuts the BS from the hvac guy way down.
Fieldpiece Instruments - Hand Held Instruments For HVAC/R Installation And Maintenence
I've had mine for a couple years and they work great, even after many falls.
Fluke and some of the other companies are also making this type.
847/736-9975
Markus Keller
05-13-2008, 05:15 AM
Re: Duct work
Markus,
That is one very nice piece of equipment you have there. I spent some time looking through the online catalog. Which model do you carry? How much should one expect to pay for it? (I didn't see any prices on their website)
05-13-2008, 06:17 AM
Re: Duct work
Allen, I have the HS36 multimeter as the primary unit, the AC current clamp head ACH4, the carbon monoxide ACM3 head and in relation to this thread the air velocity and temperature head AAV3.
The multimeter was maybe 120-140 it came with the AC clamp and a bag. The AAV3 was maybe +/- $100. The carbon monoxide head was more though. I think a couple hundred. It's been awhile. There are more heads I'd like to get, just waiting for the right job to come along to need them.
I bought the units through my HVAC supplier, I think that's where they are primarily sold.
847/736-9975
Markus Keller
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Breaks in Duct Chase |
Nick Ostrowski |
2 |
01-30-2008 09:40 AM |
| Air duct interface with slab |
Clay White |
5 |
11-19-2007 08:35 PM |
| Flex Air Duct allowed? |
Clay White |
11 |
10-18-2007 12:25 PM |
| Heat duct in garage |
Paul Kondzich |
5 |
10-17-2007 05:38 AM |
| Average cost of new duct work? |
Miriam Barton |
3 |
06-04-2007 12:44 PM |
