Old 04-28-2007, 10:18 AM
Mike Huppi Mike Huppi is offline
Heating duct rusted out in slab
I did an inspection yesterday that the lower level ducts were in the concrete slab. I smelled moisture or mildue when I entered the home so when I pulled the vent cover on two registers I found they were rusted through and there was damp rocks and dirt because the duct was rusted through along with some carpenter ants.
Does anyone know of a repair for this or does the floor have to be jack hammered up to make new ducts
Old 04-28-2007, 11:55 AM
Re: Heating duct rusted out in slab
Do what I suggested years ago when I found some like that, only the ones I found were half full of water - pump them full of concrete and install new ducts overhead.
Of the house I did, in Palm Beach (yeah, it was expensive, but it had NOT been maintained, you would think that people with money would also have common sense ... wait, why on earth would I think that ), and was two story, so it *was* a problem, but I saw no other solution. Not that big of a problem in the realm of things though, the house needed a LOT of remodeling and deferred (being nice) maintenance, so install the new ducts then.
Old 04-28-2007, 12:37 PM
Steve Brooten
Posts: n/a
I totally agree with Jerry. Ducts set in the concrete floor are going to be a problem. If not now, later. All of them I have seen have had rust or pest problems, and needed to be replaced. Pump them full of concrete and run them somewhere else! JMHO
Old 04-28-2007, 12:58 PM
Thanks thats basically what I told them the only problem is that it is on the bottom floor and they can not get to the joists so its going to be a ugly mess to say the least.
Thanks for the fast reply
Old 04-28-2007, 01:49 PM
Thom Walker's Avatar
Mike,
Can you post a picture of one of the rusted through carpenter ants?
- Paul Fix
  #6 (permalink)
Old 04-28-2007, 02:58 PM
OH you vewy funny rusted carpenter ants Ha
Similar Threads
Aluminum duct at the water heater Michael Vasquez Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 04-25-2007 01:19 AM
Passive Solar Heating Help john thurmond Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-06-2007 07:30 AM
Laars Heating Systems Recalls Gas Boilers and Water Heaters Brian Hannigan Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 03-28-2007 03:39 PM
Laars Heating Systems Recalls Gas Boilers and Water Heaters Brian Hannigan Plumbing System: Home Inspection and Commercial Inspection 0 03-28-2007 03:39 PM
8,578 Archived Heating, Ventilation, Air Conditioning Posts Brian Hannigan Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 03-21-2007 01:23 AM
vB.Sponsors
Ad Management by RedTyger
