Old 05-12-2008, 06:19 PM
Gene South's Avatar
Gene South Gene South is offline
ONE MORE TIME...LOOK AT PHOTO. WHAT IS THIS DRAIN ?
Maybe I am ignorant of just not thinking, What is this 3rd drain line on this AC. I see the main drain, the secondary and yet another one with out a PVC connection ? Look at the photo. Also, does this drain line need a PVC line that dumps into the pan ?
Gene
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Old 05-12-2008, 06:25 PM
Richard Rushing's Avatar
Re: ONE MORE TIME...LOOK AT PHOTO. WHAT IS THIS DRAIN ?
Errr.... Gene, the secondary is draining into the pan.
The primary is on the left and past the trap, there is a vent, which is capped off.
Next one...
Richard
Richard Rushing, HCRI
Duncanville, Tx.
Old 05-12-2008, 06:46 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Gene,
You show a running trap in your photo ( not allowed ) needs a P Trap for that installation.
Billy J. Stephens HI Service
Old 05-12-2008, 06:59 PM
Gene South's Avatar
Richard and Billy, I am referring to the drain opening at the far right in the photo. Is that the one you are referring to ?
Old 05-12-2008, 07:10 PM
John Arnold John Arnold is offline
This one.
  #6 (permalink)
Old 05-12-2008, 07:14 PM
Jim Luttrall Jim Luttrall is online now
Looks like an unused drain on a multi position coil. Needs to be capped.
Were you getting air into or out of it with the blower on? If you had water there, something is not as it appears.
Allen, Texas 75002
  #7 (permalink)
Old 05-12-2008, 07:20 PM
Gene South's Avatar
Jim, it was blowing air when the unit was on and otherwise dry. No moisture.
Gene
  #8 (permalink)
Old 05-12-2008, 08:23 PM
Jerry Peck's Avatar
The primary condensate line needs to be trapped "properly".
The secondary condensate line needs to be "trapped" and "trapped properly".
That copper stub out looks like what Jim said, and needs to be capped.
The 'vent' (if that what it is supposed to be) going up vertically from the downstream side of the trap, looks to me like it is a 90 elbow turning back over the pan, with another 90 degree elbow turning down into the pan, and has (has had) water dripping from it. This is not going to work as a "vent", that's for sure. My guess is that the "vent" was short and it overflowed when the primary condensate line backed up, so the tech said 'I can fix that, I'll make it drain back into the pan - simple enough to do, just install 2 90 degree elbows.'
  #9 (permalink)
Old 05-12-2008, 09:36 PM
What Jerry said
The "vent" on the primary drain line needs to be taller than the overflow of the primary pan then the secondary drain needs a trap. Oh, since the pan is now rusted out, that will need to be replaced too.
Allen, Texas 75002
  #10 (permalink)
Old 05-13-2008, 10:25 AM
Brent Crouse Brent Crouse is offline
I'm confused. If the condensate lines run directly outside, why do they need a p-trap?
  #11 (permalink)
Old 05-13-2008, 10:28 AM
Jerry Peck's Avatar
Quote:
Brent,
To keep air from moving into, or out of, the AHU.
If the AHU is a blow through style, it will blow air out through those condensate lines unless there is a trap sufficiently deep enough to resist the static pressure.
Likewise for AHU which as suck through, except that they will suck air in (instead of blowing air out).
  #12 (permalink)
Old 05-13-2008, 10:35 AM
Makes sense to me, thanks, Jerry.
  #13 (permalink)
Old 05-13-2008, 04:11 PM
Jake Guerrero's Avatar
Jake Guerrero Jake Guerrero is offline
Quote:
Brent,
What happens in the middle of January, when the trap has dried out? I think Jim L. has mentioned priming it with mineral earl (oil)..?
I think its also known as the positive and negative pressure side(s).
  #14 (permalink)
Old 05-13-2008, 07:34 PM
Jerry Peck's Avatar
Quote:
It is, but describing it as 'blow through' or 'suck through' makes a better visual understanding of what is going on.
The 'blow through' is positive pressure and the 'suck through' is negative pressure.
Plus, it not just 'positive pressure' or 'negative pressure', it's 'the static pressure' in the unit, which can be either positive or negative.
  #15 (permalink)
Old 05-13-2008, 08:29 PM
Vern Heiler's Avatar
Vern Heiler Vern Heiler is online now
Worked as HVAC tech. for a couple of years 95-97. At that time we were only concerned with traps on heat-pumps with the reasoning that heat-pumps have a negative pressure or suck air at the drain opening. With air sucking into the drain line it can create an air-dam, preventing the water from draining correctly. Most of the airconditioning units have positive pressure and blow out about as hard as a nat fart after the typical 20-30' of 3/4" pipe it runs thru. Nothing wrong with trapping it but not a huge deal. (Lets em know you were looking at it when you report it.)
As far as trapping the secondary line, it may be required by mfg. but without water or some liquid in it, it is a waste of PVC. I can't convince the homie to change the filter. Do you think he is going to crawl into an attic or crawlspace with his yuppie water bottle, to prime the trap?
I still worry most about what can cost the most, condensate sweating at the trap. It'll get you called back to do some drywall repair!
FREA Home Inspector Insurance
Similar Threads
TAKE A LOOK AT THIS PHOTO. PROBLEM ? Gene South Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 05-12-2008 06:24 PM
Photo Inspectons Michael Thomas Inspection News From Around The Net 14 01-06-2008 01:32 PM
First time long time Bob Lynett Introductions By New Members 0 10-02-2007 10:06 AM
Long time reader first time posting. Brian Ramirez Introductions By New Members 0 07-26-2007 03:50 PM
Here's one for the defect photo album... Eric Shuman Plumbing System: Home Inspection and Commercial Inspection 6 07-05-2007 04:38 AM
vB.Sponsors
Ad Management by RedTyger
