Old 05-12-2008, 05:25 PM
Gene South Gene South is offline
TXV valve mean it's a heat pump ?
Does the presence of a Thermostatic Expansion valve indicate a system is a heat pump ? If not, when is a TXV used. Some systems have them and some do not. Not sure I understand when and why.
Thx
Gene
Old 05-12-2008, 07:06 PM
Randy Clayton Randy Clayton is offline
Re: TXV valve mean it's a heat pump ?
Gene; the presence of an expansion valve doesn't mean that system is a heat pump or not. An expansion valve regulates the flow of refrigerant flowing through the system by monturing high side and low side pressures.
It is a great way of helping systems run at peek and efficiant capacites and is used on both heat pump and standard systems general cost of this upgrade (is not standard) is around 400.00
Old 05-12-2008, 07:11 PM
It generally looks like this
Old 05-12-2008, 07:18 PM
Thanks Randy. Gene
Old 05-13-2008, 09:33 AM
Could be an R410a system
847/736-9975
Markus Keller
Similar Threads
heat pump thermostat John Arnold Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-24-2008 11:50 AM
Help with age of heat pump system Jim Kasterko Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-18-2008 04:44 AM
Heat pump freeze-up Grant Harrod Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 03-17-2008 09:34 PM
Heat Pump Question Eric Shuman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 02-23-2008 08:27 AM
Heat Pump? David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 01:04 PM
vB.Sponsors
Ad Management by RedTyger
