You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-16-2008, 08:01 PM
Ross Neag Ross Neag is online now
outside intake air vs inside
Does anyone have a chart or reference as to the increased efficiency of using outside combustion air on Cat IV furnaces versus inside air (non hooked up combusition air kits)? This would help me settle an issue with a builder who claims its only 1% and helps being fresh air in...yada 3x.
Home inspection
Old 05-17-2008, 06:18 AM
Bob Harper's Avatar
Re: outside intake air vs inside
As indoor air is consumed by a furnace, replacement air must come from somewhere. You can allow the furnace to inhale indoor air instead of piping it in and the lower part of the house will depressurize enough to draw in makeup air from the paths of least resistance. This will cause cold air infiltration in places they probably do not want it. As cold air enters the living space, it will cause a call for heat and run the furnace anyway. Piping in the combustion air reduces cold air infiltration while reducing the chance of backdrafting any remaining atmospherically vented appliances.
Tell him to pipe in the air then spend his money on sealing the ducts and weatherizing the home. These unpiped Cat.IVs can be dangerous.
Bob
Old 05-17-2008, 10:37 AM
Jim Luttrall Jim Luttrall is online now
Quote:
Can't help you Ross. Have you tried the manufacturer?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 05-17-2008, 06:21 PM
I don't have a link for fact info. I have looked into it and read various things. The efficiency difference from what I have read is minimal, a few % 1-3,4. I've never seen anything that states some high rate.
I don't believe that efficiency output is the real issue or concern, either in the field or by the manufacturer's from what I have read. I have to agree with Bob that the real issues area safety and proper operation.
There are usually two points I discuss with the client:
1- starving the unit for air and poor operation; You know when they build the furnace into those nice tight little closets with solid doors.
2- creating negative pressure in the house as Bob discussed
847/736-9975
Markus Keller
Home inspection
Similar Threads
Sometimes it pays to look inside the disconnect Jon Randolph Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 01-18-2008 04:05 PM
Do Cat IV furnaces require a direct vent intake? Terry Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 09-10-2007 09:30 AM
Rust inside 2004 furnace Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 07-27-2007 04:31 PM
High Efficiency Furnace Intake/Exhaust Setup Shane Pouch Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 06-30-2007 09:46 AM
Fresh Air Intake David Banks Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 06-16-2007 09:08 PM
vB.Sponsors
Ad Management by RedTyger
