06-25-2008, 09:50 PM
Old duct from what kind of system?
The galvanized supply duct in the foreground comes from a 12 year old furnace but what is it connecting to? (I did mention the possibilty of asbestos from the friable edges of the white wrapping material.) Does this look like a component from a gravity furnace or something else?
It looks like a hole was cut into the bottom disk of the large diameter unit. I got side-tracked and forgot to check the other end - but you can see that it seems to have been 'squished' into a somewhat rectangular shape as it goes through the floor above.
Thanks,
06-25-2008, 10:28 PM
Re: Old duct from what kind of system?
Peter,
By the raging lack of responses, I would expect that no one has any idea as to what this is. Including myself. Sorry.
We have enough youth, how about a fountain of Smart?
06-26-2008, 12:28 AM
"Does this look like a component from a gravity furnace or something else?"
That would be my best guess, but only that, a guess. The wrapped duct looks about the normal size for one of those old beasts.
Another guess...Was everything on the main floor supplied by newer ducts and floor registers with that old duct feeding an upper (maybe half) floor? Easier to re-use it than to try to install a new supply duct.
06-26-2008, 06:37 AM
yes more than likely an old octopus leftover, and that Asbestos will be on ducts in the walls also and while it would be considered encapsulated within the walls, if any remodelingf is done and Asbestos is exposed it would have to be removed at that time, and you don't want to be getting that phone call.
Also there is always the chance of Asbestos fiber being pulled into the ductwork and therefore the home air by the vacume created by the air moving through the duct. Those are 50/50 deal busters,
06-26-2008, 07:03 AM
Thanks guys,
Yes, I think it was going to the second floor (of 1.5 storey) - probably would not have left that old component in the system if it was just a boot to serve the floor immediately above - wish I had remembered to follow-up while I was there.
Good point about asbestos in the wall and possibity of leakage into the airflow. I will add that to my report!
06-26-2008, 07:34 PM
Old gravity feed octopus. White stuff usually asbestos, at least around here.
06-27-2008, 06:16 AM
Peter,
I see these types of old ducts quite frequently around here, most of which are still present in 50 yr or older homes. The biggest problem as I see it is the asbestos wrap around these ducts. The friable asbestos material can be picked up in the air stream resulting in exposure to the occupants. I always recommend the boots be removed by a qualified HVAC contractor.
Bob
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Duct work |
Randy Clayton |
12 |
05-13-2008 07:17 AM |
| What kind of Siding |
Bill Wieczorek |
Building Envelope: Home Inspection and Commercial Inspection |
8 |
01-28-2008 06:12 PM |
| What kind of Truss is this |
Bill Wieczorek |
Attic Areas: Home Inspection and Commercial Inspection |
6 |
09-25-2007 03:41 PM |
| kind of an Opinion Question |
Paul Tooley |
General Chit Chat: Home Inspectors & Commercial Inspectors |
12 |
06-19-2007 10:58 PM |
| What Kind of Roof Covering is This? |
Nick Ostrowski |
Roofing System: Home Inspection and Commercial Inspection |
9 |
04-12-2007 04:39 PM |
