Old 07-12-2008, 10:26 AM
John Arnold John Arnold is online now
dryer vents into utility room
Hey, the heat from the 2 water heaters and 2 boilers dry out the damp lint, right? Quit complaining!
Old 07-12-2008, 10:54 AM
Re: dryer vents into utility room
John,
You also wrote up that foil connector as not being allowed, correct?
Old 07-12-2008, 11:04 AM
Quote:
John,
Every time.
Old 07-12-2008, 12:43 PM
Mr. Dryer Vent Mr. Dryer Vent is offline
Improper installation.
You can direct your client to our website for further assistance in your area.
Mr. Dryer Vent
Http://www.MrDryerVent.com
Old 07-12-2008, 01:13 PM
David Banks David Banks is offline
Quote:
From pic 2 it use to vent to utility room.
Dave
  #6 (permalink)
Old 07-12-2008, 03:42 PM
MrDryerVent,
Contact Brian by clicking on the 'Contact Us' link at the bottom and sponsor a link.
Brian makes this site available for free for us through advertising on the site.
Also, while contacting Brian, ask Brian to change your name to your real name, we use real names here.
Thank you.
  #7 (permalink)
Old 07-12-2008, 03:44 PM
We have real names???????????
Ted Menelly
"Castle"
Home Inspection Services
  #8 (permalink)
Old 07-12-2008, 04:24 PM
Quote:
Ok, "Ted", 'fess up.
  #9 (permalink)
Old 07-12-2008, 08:33 PM
Nick Ostrowski Nick Ostrowski is offline
Mr. Dryer Vent????? I didn't know these household parts and components had genders.
  #10 (permalink)
Old 07-13-2008, 08:28 AM
Ted Menelly ... hmmmmm ... TM .... hmmmm ... we used to have a TM post here, of course, though, *this* 'TM' and the other 'TM' do not post anything alike ... hmmmmm ... maybe this 'TM' is not the other 'TM' ... hmmmmm ... no, can't be the same.
(Thank god!)
  #11 (permalink)
Old 07-13-2008, 08:30 AM
Quote:
Nick,
I dunno, 'he' certainly must have 'big ones' to expect to be able to post advertising here without expecting to pay for that advertising.
  #12 (permalink)
Old 07-16-2008, 12:40 PM
JB Thompson JB Thompson is offline
Can't resist showing my find last Friday...
See if you can find a problem with the dryer vent.
Bruce Thompson, Lic. #9199
www.TPI-Texas.com
Tyler, TX
  #13 (permalink)
Old 07-16-2008, 12:42 PM
By the way...the rigid vertical piece is a gutter downspout (or would it be an up-spout?)
www.TPI-Texas.com
Tyler, TX
  #14 (permalink)
Old 07-16-2008, 12:58 PM
I don't like the foil dryer vent
I like the lint catcher but it seems it would allow all the humid air into the attic.
I don't like that flex gas line that looks like it is being pulled tight to the left
I see a pan under the HVAC unit with a drain line that does not go any whaere
I only see one drain line from the condenser coil box
Just looked again at the lint catcher. It vents to the attic space and should be to the exterior. I was looking wrong at first and thought it was incorporated into the line somehow
The pvc drain line looks pushed up tight against the flue pipe. can't tell what kind of flue pipe it is.
Ted Menelly
"Castle"
Last edited by Ted Menelly : 07-16-2008 at 01:18 PM. Reason: Added wording, changed wording, tired, bored
  #15 (permalink)
Old 07-16-2008, 01:08 PM
While Home Depot and Lowe's sell those bucket contraptions, it is still an improper installation and termination of the dryer exhaust.
Mr. Dryer Vent
  #16 (permalink)
Old 07-16-2008, 01:16 PM
Well. My real name is Geaorge Bush but since the Iraq war I had to hide out under Ted Menelly.
Oh yeah Jerry. Hmmmmmmmmmmmmmm, No, never posted under TM
May the real Theodore Dennis Menelly please stand up. Shoot, I can't right now my back hurts
Ted Menelly
"Castle"
  #17 (permalink)
Old 07-16-2008, 01:28 PM
me neither
yep, but it's a no-no
Not tight. It comes back in at the top of the pic
No problem, there is a float switch in the pan.
Is that a problem?
yep, exterior
it's the flue for the furnace. the pvc is not close--it's an illusion
Here is the statement that is in my report. I got a thang for dryer vents
  • Dryer exhaust ducts should be independent of all other systems.
  • They shall convey the moisture to the outdoors and shall terminate on the outside of the home in accordance with the manufacturer's installation instructions and
  • They shall be equipped with a back-draft damper.
  • Screens shall not be installed at the termination of the duct because screens and screws can trap lint.
  • Exhaust ducts shall be constructed rigid metal ducts having smooth interior surfaces with joints running in the direction of the air flow and not be connected with sheet-metal screws or any means which extend into the duct.
  • The maximum length of an exhaust duct is 25 ft. minus 2.5 ft per each 45° bend.
  • Flexible connectors from dryer to ductwork must be metal and <8 ft.
www.TPI-Texas.com
Tyler, TX
  #18 (permalink)
Old 07-16-2008, 01:36 PM
The condenser coil box only has one drain line. What if that line clogs. You have one place for the water to go and that is down thru the unit and into the drain pan.
As far as the cut off switch in the pan. SO, what if it does decide that I am not working today. Where does the water go. Oh yeah. All over the drywall ceiling down below.
There is a lot of talk about switches. I might like them but I don't trust them. If you do not write up that the pan should also have a drain line in it then when it does leak all over the ceiling whom do you think they will call.
Ted Menelly
"Castle"
  #19 (permalink)
Old 07-16-2008, 01:43 PM
I agree. But then again, how much are people willing to pay for redundancy?
Beside that, I don't think I can make the HVAC guy do more than codes allow (I can really make them do anything )
The IRC allows for a pan and switch.
What do you all think about using gutter downspouts for dryer vents? This particular builder (or his sub) does this all over town.
www.TPI-Texas.com
Tyler, TX
  #20 (permalink)
Old 07-16-2008, 02:34 PM
