Old 07-14-2008, 09:46 PM
mathew stouffer mathew stouffer is offline
Another condensate question
AC is not that popular around here so I don't know as much as I should. Each one I see seems to be different. This was in an attic and the primary was draining into a vent. However, no secondary and no trap on primary. There was a pan with a safe T switch. Another unit in the basemet only has a primary line. What's up.
Old 07-15-2008, 08:34 AM
Re: Another condensate question
At least there is a trap there, but there should be an air gap between the condensate and the trap. And that condensate line should be supported.
Man, that flexible duct sure is pulled t-i-g-h-t!
As we've stated in the past - the secondary needs to be trapped and drained, such as to the auxiliary drain pan.
Is that unit setting down in that drain pan? Or is it an optical illusion in the photo?
Old 07-15-2008, 09:59 AM
Wrong primary, wrong secondary.
Is that sewer vent open to the attic?
Both the primary AND the secondary drains should be trapped and vented DOWNSTREAM of the trap. The drain line should terminate through an air gap to an approved place of disposal, (not a vent stack)
Looks like this unit is a prime candidate to let sewer gas into the air stream.
It will also suck or blow air from the un-trapped condensate lines resulting in energy loss.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 07-15-2008, 10:01 AM
Where is that Jerry?
Allen, Texas 75002
Old 07-15-2008, 11:28 AM
Quote:
Jim,
At the vent where the condensate drain connects to the vent.
  #6 (permalink)
Old 07-15-2008, 01:55 PM
Ahh, I see now, hidden behind. I guess I need to get one of those big monitors (or maybe a pair, one for each eye)!
Allen, Texas 75002
  #7 (permalink)
Old 07-15-2008, 02:30 PM
wayne soper's Avatar
Looks like someone, Guess who? stepped on the pan edge. I wonder how much water it will hold now?
  #8 (permalink)
Old 07-15-2008, 02:41 PM
Quote:
Wayne,
No, that is from the unit being down *IN* the pan, and the pan being too small. The unit is pushing the side of the pan out. You can just see the unit pushing against it in the photo.
Of course, though, that means the pan is too small.
  #9 (permalink)
Old 07-15-2008, 06:24 PM
Thanks guys. The pan was too small, you can't see what the back looked like.
Similar Threads
Condensate switch Jim Luttrall Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 22 07-11-2008 04:33 PM
Condensate drain wayne soper Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 05-15-2008 12:12 PM
AC Condensate drain - related question Terry Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 08-24-2007 05:44 PM
Condensate? dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 06-03-2007 03:46 PM
Condensate Tray Vince Santos Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 06-03-2007 12:44 PM
vB.Sponsors
Ad Management by RedTyger
