Old 05-08-2007, 11:16 AM
John Stephenson John Stephenson is offline
Air ducts
Old 05-08-2007, 03:43 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
Re: Air ducts
03 IRC:
M1601.3.2 Support.
Metal ducts shall be supported by 0.5-inch (12.7 mm) wide 18-gage metal straps or 12-gage galvanized wire at intervals not exceeding 10 feet (3048 mm) or other approved means. Nonmetallic ducts shall be supported in accordance with the manufacturer's installation instructions.
Old 05-08-2007, 06:22 PM
Re: Air ducts
Go here ( flexibleduct.org - [ ADC_Inst.asp ] ) and click on "Click to view the "Installation Guidelines" in English or Spanish.
Or right-click above and select "Save Target As..." to download the PDF file."
"English" will get you the installation instructions in English.
Dang, if you just click on the "English" in the copy and past I did, it will take you there! The right-click-to-view-menu function was disabled, however, it did copy the shortcut when I copied that - COOL!
Similar Threads
Metal ducts Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-07-2007 03:12 AM
vB.Sponsors
Ad Management by RedTyger
