Old 09-04-2008, 08:48 PM
Peter Wigle's Avatar
Peter Wigle Peter Wigle is offline
furnace motor buzz
Tempstar High Efficiency furnace had a hum/buzz typical of a motor trying to start: With the panel removed, and depressing the cut-out switch the fan motor (or something on the electronic panel attached to it) made this sound. The thermostat was set to OFF (set to engage neither furnace nor A/C), and the fan setting on the thermostat at Auto. I didn't think the fan would be trying to start under this scenario.
When I changed the fan setting at thermostat to ON the fan would spin - after a brief delay (3-4 seconds) but with the same noise.
The house is vacant, gas turned off, and only the AC has been used in the last several months.
The fan is dirty - lots of vibration when it did run (7 years old).
The prospective buyer is having a tech in tomorrow, but in the meantime, I'm curious. Any ideas?
Old 09-04-2008, 08:55 PM
Re: furnace motor buzz
Sounds like a transformer, not the motor.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 09-05-2008, 01:36 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is online now
Transformer. I just minimized the buzzing on my rental property furnace, and it was doing exactly the same thing. I loosened the screws a little bit and isolated the transformer from the metal bracket with a piece of paper. I can still hear it, but it's much quieter.
Old 09-05-2008, 01:44 PM
Rick Hurst's Avatar
Furnace motor buzz?
Good Lord, these kids will try anything nowadays for that buzz.
We used to slam a few beers for a buzz, but I get thats not exciting anymore.
Old 09-09-2008, 03:30 PM
Dan Hagman's Avatar
Dan Hagman Dan Hagman is offline
Jim & Jim are correct, it has a 40 VA transformer making the noise. They do this all the time. It's in the way it is mounted. I have seen people hang them so they don't touch anything. Poor way of doing it. All transformers buzz.
Dan
Similar Threads
Venting gas furnace acceletaes deterioration of flue formerly venting oil furnace? Michael Thomas Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 21 06-28-2008 06:37 PM
jacuzzi tub motor bonding lug Matthew Barnicle Plumbing System: Home Inspection and Commercial Inspection 5 11-16-2007 07:11 PM
Hydro-therapy Tub Motor ? Rick Hurst Built-In Appliances and Systems: Home Inspection and Commercial Inspection 9 10-18-2007 05:38 PM
Whirlpool Tub Motor Joe Nernberg Plumbing System: Home Inspection and Commercial Inspection 1 06-29-2007 05:27 PM
Whirlpool Tub Motor Joe Nernberg Plumbing System: Home Inspection and Commercial Inspection 3 06-29-2007 08:59 AM
vB.Sponsors
Ad Management by RedTyger
