Results 1 to 13 of 13
Thread: Markusland
    Default Markusland
    Markus Keller invited me along on one of his Chicago REO "expeditions" this morning, see if you can guess which of these is NOT from the crawl space.
    Mitchell Meeks's Avatar
    Mitchell Meeks Guest
    Default Re: Markusland
    No. 4 fish mouth?
    Looks like the "big" fire didn't make it far enough.
    Michael Garrity's Avatar
    Michael Garrity Guest
    On Lake Michigan or in Lake Michigan?
    A few more.
    I thank God everyday that I do not inspect up there.
    New Mexico
    Wow. That's a mess. Where do you start in that crawl?
    Hey, those are making the Philly specials John and I see look good by comparison.
    Chicago IL
    Damn those pictures are better than mine.
    I'm recommending both buildings for demolition. Problems are to extensive to make rehab feasible, even with Govt money.
    www.aic-chicago.com
    I see the lead water service in pic #2, but what's that fitting it seems to be coming out of? I've seen a lot of lead pipes, but none that look like that.
    Chicago IL
    The slip coupling or the lead ball?
    Slip coupling repair is common when the lead pipe gets whacked by a shovel, hammer, etc. when someone is messing around down there.
    The lead ball is what makes the connection between the lead and the galv. pipe tying into it.
    Not sure which one you meant.
    www.aic-chicago.com
    The slip coupling. Thanks.
    Sep 2008
    so so, California
    Wow, thank God for sunny CALIFORNIA!
