Thread: Odd find yesterday
04-04-2015, 10:59 AM #1
Odd find yesterday
Look what I found yesterday!
04-04-2015, 12:01 PM #2
Re: Odd find yesterday
That's one for the books! Good find.
04-04-2015, 02:59 PM #3
Oh thanks Jack. Now we gotta pull on them too?
04-04-2015, 04:53 PM #4
Jack,
Sooo ... I'm to presume the water was off to the house ... ?
Great find!
Let's see ... cold water side ... must mean cold solder joint ... makes sense.
04-04-2015, 08:16 PM #5
No Jerry, the water was on to the house. When I finally got to the crawlspace, I saw that someone had disconnected the cold water line (to the washer) and capped it.
The hoses were connected to both faucets, so I was going to put one in the drain to test the waste pipes. As I was sorting out the hoses, I noticed the cold side moved a bit more than I see time to time with PEX pipe, so I checked it out.
I was shocked to say the least!
04-05-2015, 06:22 AM #6
Funny how a little clue can lead you to a big find.......and a little scary, how easily that could have been missed.
Great catch.
04-05-2015, 06:28 AM #7
Nice find Jack. I know many do not test washing machines but this is a good reason why maybe everybody should to at the very least see if the supply and drain lines are operable.
