Thread: Flue against roof sheathing
07-29-2007, 06:06 PM #1
I inspected a house today and this flue from the water heater was against the roof sheathing. I believe it needs a 1" clearance. Any help would be appreciated.
07-29-2007, 06:14 PM #2
Re: Flue against roof sheathing
07-29-2007, 06:17 PM #3
Thank you. It is single wall.
07-29-2007, 07:16 PM #4
Assuming that's an attic, can't be single wall in any case.
07-29-2007, 08:06 PM #5
I see dryer lint there, are you sure it's the water heater flue?
07-29-2007, 08:21 PM #6
Good point Dom! I have also seen bathroom and kitchen vents exhaust like that.
Michael,
How about in a house that was built before double wall vents were made?
JF
07-29-2007, 09:11 PM #7
Thank you guys for all your advice. It is not dryer lint, it is blown insulation. Yes it is the water heater vent. I put in the report that it might be a single wall and that the clearance were not correct.
