Results 1 to 3 of 3
10-07-2014, 05:10 PM #1
New Member. Question: Any problem with heat tracing exterior, insulated PEX piping?
I am a new member that has a question about PEX piping and temperatures. Can Pex piping (wrapped with insulation and encased) be used in an exterior environment with heat tracing to prevent freezing? Will the heat tracing get too hot for the Pex? And does anyone know how hot the heat tracing usually get up to? We are planning on using Z-Supply's 5" EZE Flex Silver foam 5 layer system for covering an insulating the hot and cold Pex pipes. The maximum temperature of the hot water line may get up to 200 degrees but will usually just be up to 160 degrees.
10-07-2014, 05:13 PM #2
Hi Forrest Jones and welcome to InspectionNews!
I hope you find everything you are looking for on this site.
If I can help you in any way just let me know.
If you are a business owner please accept this gift for making your first post: http://www.inspectionreferral.com
If you are a home buyer, seller or DIYer, this gift is for you: http://www.inspectionnews.net/home-i...als/member.php
Sincerely,
Brian Hannigan
Twitter: @InspectionNews
10-07-2014, 06:41 PM #3
Re: New Member. Question: Any problem with heat tracing exterior, insulated PEX pipin
Heating cable is not to be insulated. It states that right in the instructions.
