    Nov 2018
    California
    Question Outlet receptacle requirements.
    Capistrano Beach, CA
    Default
    Welcome to InspectionNews!
    Thank you for registering and posting your message here.
    If there is anything I can help you with please let me know.
    InspectionNews has many Member Benefits available to you. Some save you time, others save you money and some do both!
    Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Outlet receptacle requirements.
    Quote Originally Posted by Mariely Romero View Post
    How many outlets does a master bathroom with 2 sinks require?
    Depends on how close the sinks are to each other.
    A receptacle outlet needs to be within 3 feet of the water's edge for each sink.
    Oct 2010
    MONTREAL QUEBEC-CANADA
    Marliey, welcome to Inspectionnews.
    Bathrooms are a special area considering they are a damp wet environment.
    A bathroom requires at least (1) one 120-volt receptacle within 3 feet of the outside edge of each sink basin. Duel sinks can be served by a single receptacle positioned between them.
    Every bathroom must have at least one electrical outlet. It must be a GFCI, and it must be within 3 feet of the edge of the sink. Either behind or beside the sink is acceptable -- across from the sink on an opposite wall is not. If the bathroom has two sinks, each must have an electrical receptacle within 3 feet. This may mean placing the outlet between them or installing two separate outlets. Additional outlets are allowed in various locations in the bathroom but cannot replace this required outlet. If they're within 6 feet of the sink, they must be GFCIs.
