Results 1 to 3 of 3
Thread: newbie
    p dohm's Avatar
    p dohm Guest
    Thumbs up newbie
    Hi folks,
    I'm new to the business and this site.
    Could use some advice as to what equipment is recommended. There are a lot of choices out there and don't want to risk buying junk or over doing it either.
    The items of interest at this point are: Moisture Meter, inspection scope, Carbon Monoxide Detector, Thermal imagers.
    I'm sure there is a wealth of knowledge and advice from the experienced inspector and would appreciate some tips.
    Phil
    Default Re: newbie
    Phil,
    I've got a whole box of tools I thought I just had to have at the moment and now realize I don't use them as I thought I would.
    I would suggest starting out with a great flashlight, electrical testers, carbon-monoxide and a moisture meter. Hold off on the thermal imager a while.
    I was always told if you buy quality tools you only cry once, you buy cheap tools you'll cry every time you use them.
    Best of luck.
    Default Re: newbie
    Welcome Phil!
    Try doing a search, including the archive of the previous incarnation of inspection news - you will find a plethora of opinion as to what is necessary. I overdid it when I got started. There are perfectly good inspectors, for instance, who do not own carbon monoxide testers, or scopes or thermal imagers of any kind. Heck, I don't even have an MRI machine!
