Old 08-21-2007, 11:07 AM
Dave Boratyn Dave Boratyn is offline
Gas meter in relations to A/C
Hey Guys. New to this InspectorNews. I had a new construction inspection & one of the A/C compressors was off the pad. I asked why. Builder Supr. said something about it being too close to the gas meter. I looked thru ICC book, didn't see any info. regarding distances. Is there such a code??
Home inspection
Old 08-21-2007, 11:16 AM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Re: Gas meter in relations to A/C
National Fuel Gas Code 54-5.7.2.3 “Gas meters shall be located at least 3 ft. from sources of ignition.” Ignition is considered anything that can ignite gas, such as electric motors, switches, outlets and most exhaust/vent terminations such as furnace and/or dryer vent. 3 foot clearance also applies to windows that can be opened and/or crawlspace vents.
I measure from the gas port on the gas regulator
I say lets merge all the home inspection organizations into one.
Seepaluce
Old 08-21-2007, 01:14 PM
Thanks Kevin. I had heard of 3 to 5 feet but didn't have anything to back it up. Thanks again!
Similar Threads
Breaker box at utility meter John Stephenson Electrical Systems: Home Inspection and Commercial Inspection 1 06-01-2007 10:39 AM
GAS meter wayne soper Plumbing System: Home Inspection and Commercial Inspection 5 05-11-2007 08:30 PM
Gas meter location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 1 05-07-2007 06:21 PM
rust on gas meter Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 4 04-16-2007 12:46 PM
Gas meter David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 04-13-2007 04:37 PM
vB.Sponsors
Ad Management by RedTyger
