Old 04-08-2008, 06:44 PM
Manzoor Husain Manzoor Husain is offline
Hot Water Heater TP valve drain pipe
Hi, This is Manzoor
I have recently seen that in new homes they are using a flexible copper pipe in the drain line of the TP valve. I had always thought that this pipe has to be solid copper, steel or cpvc. Has any one else experieced this ? Is it code compliant to use flexible pipe?
Home inspection
Old 04-08-2008, 06:47 PM
Rick Hurst's Avatar
Re: Hot Water Heater TP valve drain pipe
Those flex type copper lines are reduced and not 3/4in. inside diameter as required.
Therefore they are not acceptable.
Rick
Old 04-08-2008, 07:37 PM
Jerry McCarthy's Avatar
Ditto Rick. Refer IRC 2006 P2803.1(3)
Construction Consultant
Old 04-20-2008, 10:32 AM
Thank you for pointing out the reduction in the diameter of the pipe.I am surprised that the code inspectors don't consider this a problem.
Similar Threads
Soot above water heater TPR Valve Jon mackay Plumbing System: Home Inspection and Commercial Inspection 14 03-20-2008 06:01 AM
Water heater vent pipe wayne soper Plumbing System: Home Inspection and Commercial Inspection 3 07-25-2007 06:46 PM
Upsized water heater vent pipe Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-30-2007 11:32 AM
Water heater valve Gregg Austensen Plumbing System: Home Inspection and Commercial Inspection 9 04-24-2007 09:06 PM
ABS Flue Pipe on LP Water Heater Trey Humphreys Plumbing System: Home Inspection and Commercial Inspection 6 04-03-2007 02:11 PM
vB.Sponsors
Ad Management by RedTyger
