Thread: pressure booster system?
11-03-2008, 03:55 PM #1
I've never seen a pump and tank connected to public water. I assume it's to boost pressure, but I don't like assuming things.
Any words of wisdom?
10 year old 5 bed 4.5 bath relatively high end home.
11-03-2008, 04:56 PM #2
Re: pressure booster system?
11-03-2008, 05:42 PM #3
The only reason I can think of for that on city water is to boost the water pressure, typically, that is done only on larger homes with other than barely adequate city pressure.
I've seen them before, but none of which looked like that.
The ones I've seen looked liked the 2nd and 3rd ones shown here: Water Pressure Booster Pump - Tools - Compare Prices, Reviews and Buy at NexTag - Price - Review
As can be seen, though, there are other types.
11-03-2008, 06:02 PM #4
John,
I see systems like this periodically. Generally located on hills where the water pressure is low. Around here, annual inspections are required by the city. I think it is to ensure that the check valve is functioning properly. The pump size does not look extraordinarily large.
11-03-2008, 06:07 PM #5
Looks like a pressure reducing valve at the entry to the home and then a jet pump and pressure tank. Kind of strange to reduce the pressure and then increase it with a pump. Some towns with reservoirs at high altitudes create too much pressure at the house so must be reduced and then more than likely set at proper pressure to keep the pressure tank system worling. The tank will hold a few gallons that will allow even pressure to whatever is being supplied by the Larger line at right which may go to a larger jetted tub on upper level but more than likely to the sprinkler system at the exterior. Which is usually evidenced by the added shut off valve. Was there a sprinkler system outside?
Or mabey it was a brokers house and they needed extra pressure to the BIDET
11-03-2008, 06:11 PM #6
11-03-2008, 06:18 PM #7
11-03-2008, 10:08 PM #8
A check valve would be required on the city side for the pump to work properly (and likely required by the city) so the regulator may be a combo unit that was on the truck.
