Results 1 to 12 of 12
Thread: Unknown piping.
05-13-2007, 10:46 AM #1
Unknown piping.
Ran across this yesterday. Not sure what it is for. On the outside there was this configuration (photo1) and on the inside a closed loop of pvc pipe (photo 2).
Any ideas? I thought maybe a water softener hook up that is not used but I haven't seen this set-up before.
Any ideas?
Thanks,
Eric
05-13-2007, 10:57 AM #2
Re: Unknown piping.
Is the gray line teed into the loop or is the sock just holding the open line against the loop?
- Paul Fix
05-13-2007, 12:03 PM #3
Re: Unknown piping.
The sock is just holding the gray line crimped over and against the loop.
Thanks,
Eric
05-13-2007, 12:10 PM #4
Re: Unknown piping.
There used to be filtration system/treatment system equipment in that room?
05-13-2007, 12:13 PM #5
Re: Unknown piping.
That is what I was leaning towards.
Eric
05-13-2007, 12:20 PM #6
Re: Unknown piping.
I think you are dead on.
- Paul Fix
05-13-2007, 06:17 PM #7
Re: Unknown piping.
No, you're dead off.
It is a heat loop (using the ground and home heat) to keep the faucet from freezing.
OK, OK. It's just a wild thought that popped into my head when I saw the pictures.
05-13-2007, 06:47 PM #8
Re: Unknown piping.
Some sort of backflow preventer?
Bruce Breedlove
www.avaloninspection.com
05-13-2007, 07:18 PM #9
Re: Unknown piping.
05-13-2007, 09:41 PM #10
Re: Unknown piping.
Eric,
Let us know.
- Paul Fix
05-14-2007, 06:12 PM #11
Re: Unknown piping.
O.K.
I inspected a one year old house today and found a very similar set-up attached to a water softening system in the garage. Photos 1-2. So back to "Dead on" I guess.
I have seen plenty of softener installs but not with this particular set-up.
This one today even had the hose bib and all just like the other.
Todays inspection also had this nice support sytem for a 65 gallon water heater and furnace/evaporator coil combo in a second floor closet! See photo 3. Needless to say, the deck they were resting on was sagging a bit.
Eric
05-14-2007, 07:09 PM #12
Re: Unknown piping.
Thanks for following up.
- Paul Fix
