Results 1 to 3 of 3
    Bob Lynett's Avatar
    Bob Lynett Guest
    Default Water heater flue connection
    I have never seen this type of hook up before. The water heater flue is connected to a large flue going into chimney coming from a wood stove burner in the basement. If I read the code check correctly it states water heater flue pipe cannot be connected to masonry chimney through a solid wood burning flue fireplace/heater as shown in this picture I took. Is this correct?
    Richard Pultar's Avatar
    Richard Pultar Guest
    Default Re: Water heater flue connection
    can't mix solid fuel and gas ,,you are corect
    Bob Lynett's Avatar
    Bob Lynett Guest
    Thanks for the reply Richard.
