Results 1 to 18 of 18
Thread: Reft or Light???
01-14-2009, 02:17 PM #1
Reft or Light???
Is there a correct side for the Hot and Cold, on a garden tub with faucet controls on the entry side of the tub? I see them both ways.
01-14-2009, 02:21 PM #2
Re: Reft or Light???
Unless the original home buyer specified something different, the hot should be on your left when you are in the tub.
So it would be on the right as pictured.
Or better yet, anyway you want it as long as a color stripe or indication is present.
01-14-2009, 02:38 PM #3
No stripe. Just turn one and see what happens!
01-14-2009, 02:51 PM #4
Vern:
P2722.2 Hot water.Fixture fittings and faucets that are supplied
with both hot and cold water shall be installed and
adjusted so that the left-hand side of the water temperature control
represents the flow of hot water when facing the outlet.
Exception:Shower and tub/shower mixing valves conforming
to ASSE 1016 or CSA B125, where the water temperature
control corresponds to the markings on the device.
Hot is always on the left as your face the fixture.
01-14-2009, 02:52 PM #5
01-14-2009, 03:40 PM #6
Thanks all, I am going down the middle with this as the outlet can be faced from either side. Just going to make a note of which way in the report.
01-14-2009, 04:03 PM #7
Hot or cold..... guess?
01-14-2009, 04:06 PM #8
Two wrongs don't make a right, but three lefts do.
01-14-2009, 04:28 PM #9
Re: Right or Left???
01-14-2009, 04:44 PM #10
01-14-2009, 04:58 PM #11
01-14-2009, 05:20 PM #12
Like Aaron posted left when facing the OUTLET.the left-hand side of the water temperature control
01-14-2009, 05:34 PM #13
01-14-2009, 07:22 PM #14
01-14-2009, 09:24 PM #15
Here's a sink faucet I encountered a couple weeks ago that was reversed. It looked like the faucet was installed backwards due to a lack space between it and the back splash.
The red/blue indicator was set in line with what was coming out of the faucet but the hot was coming from the right side. Actually, the red/blue tab couldn't be reversed so I assumed the plumber/installer just followed that.
In any case, looked up the same codes that A.D. Miller posted and determined the install was incorrect since it's not a tub/shower.
btw.... West Coast Jerry... what kind of gas station rest rooms are you hanging out in? That place looks pretty bad
01-15-2009, 12:08 PM #16
FWIW,
Providing a uniform configration (hot on left) goes a long way to helping the blind.
On a side note, notice the salt next time you go to a restaurant - it should be on the right.
01-16-2009, 09:20 AM #17
Cold water on wight, hot on reft.
01-18-2009, 10:55 AM #18
That just looks so wrong. Slipping while climbing in and out could result in unintended encounters w/ the hard sufaces of the fixtures or even more scary snagging scenarios(sp?).
