Thread: Water temperature fluctuation
01-17-2009, 03:25 PM #1
Hello gentlemen, Just in a condo building that has a central water heater. The condo unit has 2 showers. The hall shower operates properly. The master shower starts out with a normal (warm) temperature than it starts to fluctuate between scolding hot & ice cold. Any ideas to the cause.
Thanks in advance.
01-17-2009, 03:53 PM #2
Re: Water temperature fluctuation
It may have a mixing valve which is bad.
01-17-2009, 04:45 PM #3
Jerry, you forgot to post code text.
Individual shower valves. Individual shower and
tub-shower combination valves shall be balanced-pressure,
thermostatic or combination balanced-pressure/thermostatic
valves that conform to the requirements of ASSE 1016 or CSA
B125 and shall be installed at the point of use. Shower and
tub-shower combination valves required by this section shall
be equipped with a means to limit the maximum setting of the
valve to 120°F (49°C), which shall be field adjusted in accordance
with the manufacturer’s instructions. In-line thermostatic
valves shall not be utilized for compliance with this
section.
01-17-2009, 05:52 PM #4
01-17-2009, 08:06 PM #5
Bad valve about does it
