Thread: Dishwasher
05-21-2007, 02:53 PM #1
Dishwasher
Homeowner special. Dishwasher away from sink so the hooked up feed and drain directly through floor into basement.
Any good writeup suggestions. Is there a siphon issue with no high loop?
Feed line has no shutoff and dubious connection.
05-21-2007, 04:03 PM #2
Re: Dishwasher
David,
If memory serves, no p-trap allowed below floor level (except tub/shower). I think you mentioned no airgap.
05-21-2007, 05:47 PM #3
Re: Dishwasher
No vent - that's a big problem.
No air gap, either into a disposal, air gap, or into a tailpiece fitting, all of which allows for an atmospheric break between the water being pumped out and the drain gravity draining away.
There is a potential for cross connection.
Accessibility of the trap could be a problem.
There is a minimum/maximum fall distance to the trap, but everything is screwed up, so that cannot even be measured.
Those should serve as good starting points.
05-21-2007, 06:51 PM #4
Re: Dishwasher
Thanks Jerry that helps a lot. Plumbing not one of my strong points.
