Results 1 to 10 of 10
Thread: Airgap!
    Default Airgap!
    This is the very first time I have seen an airgap installation on a filter system. This was a Culligan reverse osmosis installation and it had an airgap and a p-trap. I was astounded. Normally, I see a saddle connection that discharges through a hole drilled into the sink drain pipe. It is the white cylindrical doohickey next to the disposal. The discharge tubing enters the top, the front of the airgap/cylinder is open. Sorry about the quality of the pic. Somewhat overexposed.
    I got so excited, that I just had to share.
    Default Re: Airgap!
    I guess it is designed so the water does not back up into the overflow line and contaminate the water. Hmm. Makes sennse to me.
    Default Re: Airgap!
    Neat ... but ... what happens when the drain backs up and ... starts to back up into the disposer ... ?
    Why do I always have to be the one to ruin a good party?
    Default Re: Airgap!
    Neat ... but ... what happens when the drain backs up and ... starts to back up into the disposer ... ? Why do I always have to be the one to ruin a good party?
    You really are killjoy. With proper maintenance, the sink should <never?> back up. But, have you ever seen anything like this? I suppose the R/O drain could go into a dishwasher airgap, but then you would end up with two of those little chrome R2D2 things on your sink.
    Peter Taheny's Avatar
    Peter Taheny Guest
    Default Re: Airgap!
    Gunnar
    Just one.
    Default Re: Airgap!
    Only once, and I had the same question then.
    My client looked at it, looked at the hole, looked at the sink so far above it, then said '(non-repeated word)! That thing backs up and I've got a cabinet full of crappy water!', or words to that effect. I said 'Yep. That's what I'm talking about.'
    Peter Taheny Guest
    Default Re: Airgap!
    Gunnar
    It also appears that there are two traps on that trap arm.
    CPC 2007 § 1001.1 … Not more than one (1) trap shall be permitted on a trap arm.
    CPC 2001 § 1001.1 … Not more than one (1) trap shall be permitted on a trap arm.
    Default Re: Airgap!
    Ooh, I hadn't caught that. Thanks.
    New Mexico
    Default Re: Airgap!
    Most of the RO systems that are newer have a built in air gap for the drain. It runs uphill to the dispenser, and then back down to the drain.
    Default Re: Airgap!
    I haven't seen that. Do you have a pic?
