Results 1 to 13 of 13
Thread: Can anyone tell me why this is
03-04-2009, 07:40 AM #1
03-04-2009, 08:42 AM #2
Re: Can anyone tell me why this is
Git er dun! is what is says.
Did you check the clearances from the drywall on the attic side? Most installs as such will be in contact with the drywall 99% of the time.
03-04-2009, 08:56 AM #3
Thanks Rick,
I did and it was in the 99%. How would you write the remedy or solution to this
Jim
03-04-2009, 08:59 AM #4
My guess would be laziness on the plumbers part. They just used what they had and didn't want to go to the supply house to get the correct length of vent pipe to make that transition.
Dylan Whitehead
03-04-2009, 10:02 AM #5
There is too much wrong with the photographed and described photo to presume it was done by a licensed qualified tradesman.
You can mention the clearance and unsupported penetration and unstrapped/unsupported offsets and unsupported vertical if you feel comfortable doing so.
Would need many more details and photos to nail down each and every defect but there are many.
Call for Level 2 Inspection and correction of the gas vent for the gas-fire domestic water heater.
03-04-2009, 10:24 AM #6
Thanks for all of the help!
Jim Murphy
03-04-2009, 11:51 AM #7
Yep, have seen similar things all the time done by LICENSED contractors of all trades.
No need to make an assumption that it was *not done by* licensed contractors just because it was done so poorly. That's what keeps HIs in business.
03-04-2009, 12:05 PM #8
03-10-2009, 12:42 PM #9
I would say the installer was short on pipe and used fittings to make up the difference. The problem with that is, each of those elbows is equal to a certain number of feet of pipe. Depending on how far that vent runs, they may be over on footage.
03-10-2009, 02:07 PM #10
Last edited by H.G. Watson, Sr.; 03-10-2009 at 02:09 PM. Reason: Corrected spelling of Mr. Murphy's name.
03-10-2009, 03:53 PM #11
And I said:
Very much equal in the logic department.
Having been around construction and inspection for a very long time, I have seen so many deficiencies done by "licensed qualified tradesman" that there is nothing there to presume other than it was done by them.
Of course, that term "licensed qualified tradesman" is a poor term and has been discussed here at length:
- In areas which require licensing, one must be licensed, and, when one is licensed, that makes them qualified.
- In areas which require licensing, being qualified means one is licensed.
There is another term many of us have started using: "licensed and competent" as that term indicates that not only is one "licensed and qualified" but that they are also "competent" to do the work.
I have seen "competent" workers who were not licensed, therefore they were not "qualified" to do the work, but they sure did it a lot better than "licensed and qualified" contractors.
03-10-2009, 03:59 PM #12
....*Sigh*.....
03-10-2009, 04:32 PM #13
