Results 1 to 3 of 3
    Bob Jack's Avatar
    Bob Jack Guest
    Default flex gas line through solid walls ???
    Inspection on a six year old modular home in Vermont. There were flexible LP gas lines run through the walls and floor joists including the exterior wall to the storage tank. Can I get clarification on not allowing flexible gas lines being run through a solid wall??
    Default Re: flex gas line through solid walls ???
    Something like this?
    Er, uh ... this is the same thread as that other one with the same question only without the photo.
    http://www.inspectionnews.net/home_i...lid-walls.html
