    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Dishwasher drain line connection
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Dishwasher drain line connection
    See all the time with a hose clamp.
    However, that drain line does not have a "high drain loop" as needed.
    (see attachment).
    Richard
    Rich,
    Nice diagram. Illinois in their infinite wisdom does not allow dishwashers to discharge into disposers. Concern is that the disposer could force waste back into the dishwasher.
    Our dishwasher here at home has no loop AND runs into the disposer. I'm very defiant and will likely die a horrible and meaningless death as a result of dishwasher poisoning.
    Corpus Christi, TX
    It is tres gross when it happens; siphoning, not death.
    - Paul Fix
    South-West Michigan
    Post Re: Dishwasher drain line connection
    Well, it appears that it has leaked before, so I would say no. The discharge line coupling is too large for the extension tube nipple. A rigid reducing coupling should be added, along with a smaller Fernco coupling, so that the coupling is properly sized for the extension tube nipple. The visible corrosion suggests that this fitting, as currently installed, weeps from time to time, and will eventually fail. If the nipple were to rot off the extension tube, and one were to cycle the dishwasher, it could get really interesting.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
