Results 1 to 10 of 10
    Norm Peery's Avatar
    Norm Peery Guest
    Default TPR stand pipe material Help
    Can anyone tell me if this pvc is rated for use on a TPR?
    Thanks,
    Norm
    Matt Vozzella's Avatar
    Matt Vozzella Guest
    Default Re: TPR stand pipe material Help
    Based on the ASTM rating (D2846) it seems to be CPVC not PVC.
    Quote Originally Posted by Norm Peery View Post
    Quote Originally Posted by Matt Vozzella View Post
    And, to answer his question , yes, CPVC is allowed to be used for the T&P discharge line.
    However, ... how old is the house? This may lead back to another thread about where that is required to terminate. for Matt
    Matt Vozzella Guest
    Good catch, I like it, sort of. Don't know where it's going to give a firm answer.
    Norm Peery's Avatar
    Norm Peery Guest
    Sorry knew it was cpvc, but the 100 psi rating raised a question. When those blow 100 psi seems pretty low
    Norm
    Matt Vozzella Guest
    Norm
    They aren't holding pressure as long as someone didn't do something stupid like put a cap on the end.
    Norm Peery's Avatar
    Norm Peery Guest
    DUH...................................... Thanks Matt. What's that saying ...... something about the forest and the trees
    Norm
    Matt Vozzella Guest
    No worries, I know I've done it a time or two. A common outcome when you like to shoot from the hip on an issue.
    Peter Taheny's Avatar
    Peter Taheny Guest
    Pipe OK
    Solvent Cement OK
    Fittings, Not OK
    Fitting appears to be PVC if they were CPVC they would have the same coloration as the pipe.
    Photo rotated and lightened.
    Quote Originally Posted by Peter Taheny View Post
    Pipe OK
    Solvent Cement OK
    Fittings, Not OK
    Peter,
    PVC and CPVC is sized differently.
    They and their fittings are not interchangeable.
