Results 1 to 16 of 16
    RobertSmith's Avatar
    RobertSmith Guest
    Default embarrassing question
    I must confess, this is an embarrassing question, I'm having a brain dump.
    The green substance , chemicals on copper water supply lines, faucets you typcially see is known as oxidation or corrosion?
    Sorry for the question, been working too hard I guess!
    Rob
    Inspection Referral SOC
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: embarrassing question
    Galvanic action.
    Best
    Ron
    Oxidation
    What is Oxidation?
    RobertSmith Guest
    Raymond,
    Great little article, thanks!
    Rob
    Joe Asta's Avatar
    Joe Asta Guest
    copper patina? Corrosion?
    Quote Originally Posted by RobertSmith View Post
    Quote Originally Posted by Joe Asta View Post
    Yes to all of the above.
    What is Corrosion?
    Oxidation and/or corrosion - not quite completely interchangeable in all uses but are interchangeable in some uses.
    51386. The difference between corrosion and oxidation? [Japan]
    I must confess, this is an embarrassing question, I'm having a brain dump. The green substance , chemicals on copper water supply lines, faucets you typcially see is known as oxidation or corrosion? Sorry for the question, been working too hard I guess! Rob
    Verdigris.
    Verdigris - Wikipedia, the free encyclopedia
    Jun 2009
    Windsor, CA
    I have a question. Is it just the exterior of the pipe or is it staining the inside of the sinks?
    Robert Autrey's Avatar
    Robert Autrey Guest
    The question I have is will it soon lead to leaking. Should the components be replaced?
    South-West Michigan
    Post Re: embarrassing question
    Nice information Jerry. If the joint is clean and the amount of oxidized copper is minimal, I usually note it as "oxidation". If there appears to be excess flux that was never removed, causing deterioration of the pipe or fitting, I usually note it as "corrosion".
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Mike Truss Guy's Avatar
    Mike Truss Guy Guest
    Isn't oxidation a type of corrosion that happens in when metals are exposed to the oxygen in air?
    Quote Originally Posted by Mike Truss Guy View Post
    Basically, I think, it goes through oxidation first. Everything oxidizes, some at slower rates that others. Once the oxidation has progressed to the point of causing a detrimental effect on the material which has oxidized, that now becomes corrosion, which makes the material corroded, which means the material has been negatively affected by the oxidation.
    Or something like that.
    Like when steel oxidizes and forms surface rust, which helps protect the steel, yet more rust becomes corrosion and the steel is degraded.
    Huntsville, Ontario
    I see this in my area. At times the oxidation/corrosion is excessive and damp (beginning to leak). My plumber freinds tell me it due to low PH (below 6.5) well water, which is typical is this part of the country.
    I write it up as potential leaks and/or currently leaking depending on the actual observation.
    Steve Bowman
    Top To Bottom Home and Property Inspections
    Robert Autrey Guest
    Maybe I can ask my question a different way? Does anybody know? I see this type of corrosion (I'll call it that for now) all the time. Some of the responses here seem to indicate that it will occur even without a leak being present. Is that the consensus opinion? And, if so, will it eventually cause a leak? Maybe? Probably? I can see that it could occur without a leak being present, but it has to be damaging, or depleting, the metal. Right?
    The green substance ... on copper ... you typcially see is known as oxidation ...
    I'll answer the question differently ... Yes.
    Robert Autrey Guest
    Smile Re: embarrassing question
    Thanks! That's the answer I was looking for!
