Thread: Sewage pump
07-27-2009, 11:09 AM #1
Sewage pump
A basement laundry area uses a sewage ejector pump to remove only laundry waste water up to the level of the house drain. The unit's vent terminates about 4 feet above the pump housing. Is a proper plumbing vent not required, could a "cheater" or automatic vent be used?
(Ignore the NMD - separate issue)
07-27-2009, 11:31 AM #2
Re: Sewage pump
Not sure about Ontario,but down here in New York it should be vented separately.But if it is just laundry waste,would it be a major problem if it was connected into an existing vent?Where is the check valve?
07-27-2009, 01:26 PM #3
Re: Sewage pump
It should tie into an existing vent. A cheater vent on a pump box or ejector pit is not correct. It is best to check with your local plumbing inspector. Since codes always vary from place to place.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
07-29-2009, 02:17 PM #4
Re: Sewage pump
In some areas an air check vent is acceptable.
07-29-2009, 02:30 PM #5
Re: Sewage pump
In Ontario it has to be vented.
07-29-2009, 03:00 PM #6
Re: Sewage pump
07-29-2009, 03:24 PM #7
Re: Sewage pump
FWIW that set up with the vent is NCC. (non-code complying)
