		Thread: water heater exhaust damper
	08-15-2009, 11:22 AM #1 water heater exhaust damper water heater exhaust damperToday I saw a high efficiency water heater that exhausts through pvc terminate at a back-draft damper outside. This can't be right, can it?
	08-15-2009, 02:04 PM #2 Re: water heater exhaust damper Re: water heater exhaust damperJA: It is my understanding that ultra-efficient heaters use sealed-combustion technology so they cannot backdraft. The damper would then be moot, if not specifically disallowed.
	08-15-2009, 02:09 PM #3 Re: water heater exhaust damper Re: water heater exhaust damperIt's a Rheem power vent and I looked up the installations specs. While they don't say "no back draft damper", they don't show one as an option, either. Just the pipe with a supplied screen.
	08-15-2009, 02:24 PM #4 Re: water heater exhaust damper Re: water heater exhaust damperJA: I cannot think of a reason why it would be prohibited, but I have also never seen this installation before.
	08-15-2009, 03:05 PM #5 Re: water heater exhaust damper Re: water heater exhaust damperJohn, is it possible that the damper could freeze closed due to the moisture in the products of combustion? I've never seen one on high efficiency equipment.
	08-15-2009, 03:37 PM #6 Re: water heater exhaust damper
		"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961) Re: water heater exhaust damper
  Reply With Quote Originally Posted by neal lewis
