Thread: water heater TPR arrangement
08-24-2009, 03:03 PM #1
the building official told the builder he could do it this way or so it was stated.
This has a solar heater on the roof with a recirculator. I was not sure if the tpr drain line could be t'd off with a return or supply?
08-24-2009, 03:31 PM #2
Re: water heater TPR arrangement
It can be done like that if they used the right T&P relief valve-- they need the longer style-- it has to extend into the top 6" of the tank I believe.
The above info. is from what I have learned here, and is based on memory--- I can't say I've ever seen it done that way.
08-24-2009, 04:06 PM #3
Hey Brandon...
You should check these fittings. some of them have a stamp on the side of them stating cold water only.
Best
Ron
08-24-2009, 05:09 PM #4
Correct ... as long as the T&P has the extra long probe, usually designated by and XL instead of just an L, for example: 100XL, 1L, 1XL, 40L, 40XL, etc. ( Watts: Temperature and Pressure Relief Valves | Water Safety & Flow Control ).
Also note that there appears to be a heat trap fitting in the two solar heater lines but NOT in the hot out, which is where a hot heat trap is needed.
08-24-2009, 05:29 PM #5
good stuff, thanks
08-24-2009, 05:31 PM #6
08-24-2009, 06:01 PM #7
Hey Brandon...
Good memory.....
http://www.inspectionnews.net/home_i...ater-only.html
08-24-2009, 07:06 PM #8
That's those transition fittings I keep mentioning since that thread came up and that information was posted.
What you are looking at are "adapters" to "adapter" from a slip joint to a threaded joint, not "transitions" which "transition" from one material to another.
