Thread: Trap Primer
09-04-2009, 03:32 PM #1
Trap Primer
HVAC unit installed in a hall closet. The condensate drain line is piped into a 2” pipe. The 2” pipe travels downward into the return air space, into a 2” p-trap, then travels into the adjacent wall.
From the attic in the utility closet, there is a copper supply line that travels downward and has a PPP prime-rite trap primer on the end. A small copper stub is connected to the trap primer which extends a couple of inches into the 2” pipe along with the condensate drain line.
Based on what I found here, how will the trap primer work? Am I missing something?
09-04-2009, 04:25 PM #2
Re: Trap Primer
The priming valve is automatically activated when it senses a pressure drop of 5 to 10 P.S.I.G. (35 to 70 kpa).
09-06-2009, 07:59 PM #3
Re: Trap Primer
Jim, thanks.
09-06-2009, 08:06 PM #4
Re: Trap Primer
I figured Jerry or one of the plumbers would chime in on your photos by now, but I will go ahead and mention the improper clearance on the "indirect" connection of the drain.
