Results 1 to 22 of 22
Thread: S Traps
09-17-2009, 11:43 AM #1
S Traps
How long have S traps not been allowed?
09-17-2009, 12:16 PM #2
09-17-2009, 02:13 PM #3
Re: S Traps
Thanks A.D., how about it Jerry can you tell me when?
09-17-2009, 03:19 PM #4
Re: S Traps
Well, in my first life ... Ung told Unk to shave and Unk asked "With what? No shavers have been invented yet."
Okay, I don't know when 'S' traps were not allowed, but as I recall there was a discussion on this last year or so and someone found something which indicated they were disallowed back in the 1920s or so.
I could look it up on historical Uniform Plumbing Codes CD, but they are a pain to use and find things on.
The real answer is: "It does not matter when they were no longer allowed, they were no longer allowed for a very good sanitary reason and that reason still existed back when 'S' traps were being installed." Just because it took years and decades to prohibit a practice never makes that practice safe to have ever been installed, much less left to exist to today.
09-17-2009, 03:26 PM #5
Re: S Traps
It's amazing how many houses around here have S traps. And not just the many, many very old houses. It's completely unsurprising to find them in relatively new homes. These things seem to vary considerably by region, it seems, as far as enforcement goes.
09-17-2009, 04:11 PM #6
Re: S Traps
John, I called out an S-trap on a sink in a new home a couple years ago. The builder rep who was standing there said "Do you have S-traps in your house?". I said "Yeah, but my house is 110 years old. This is brand new".
I have to admit that I just stopped mentioning the presence of S-traps unless the house is newer as I just see too many of them.
09-17-2009, 04:26 PM #7
Re: S Traps
This house was about 15 years old, although I did find one in brand new construction last year. I knew they had not been allowed for a long time, but just not how long.
Typical agent trying to say that the house did not need to be brought up to current codes, she also said she has never had an inspector mention wood debris in the crawlspace.
09-17-2009, 04:29 PM #8
Re: S Traps
09-17-2009, 05:07 PM #9
Re: S Traps
09-17-2009, 08:28 PM #10
Re: S Traps
I know they're not a hard fix but nobody (from my experience) wants to bother with fixing them unless their drain is not emptying properly. If their sink empties and doesn't back up, they don't care.
S-traps don't even make my reports anymore.
09-17-2009, 08:36 PM #11
Re: S Traps
As long as the AAV is allowed by local code. A lot of newer homes that have had the kitchens remodeled by a non-plumber you will find an S-trap installed when the move the kitchen sink off the wall.
AS to when they have been not allowed depends on what code book you read. I have one here from 1918 where they did not allow S-traps unless they where crown vented. Also have a 1920 code book that says s-traps, bell traps, and crown vented traps are not allowed.
I bet if you called in the local plumbing inspector, or state inspector in case you do not have a local one, and they will tell you the S-trap needs to be removed and the drain properly vented.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
09-17-2009, 08:38 PM #12
Re: S Traps
09-18-2009, 04:30 AM #13
Re: S Traps
But then again as often as AAV's fail the S may not be all that bad.
09-18-2009, 04:36 AM #14
09-18-2009, 06:21 AM #15
09-18-2009, 08:18 AM #16
Re: S Traps
I don't call them out for repair either. They're extremely common in the Phila. area and you'd have a hard time convincing anyone that the risk is worth the cost to replace them.
Just thinking out loud, maybe the way to go is to include an FYI note in the report to the effect that "Sink drains in the house use 'S' traps. Modern plumbing standards no longer allow 'S' traps because they can siphon dry during drainage, potentially allowing sewer gases to enter the home. ..."
Wimpy? Asking for trouble?
John
09-18-2009, 08:23 AM #17
Re: S Traps
09-18-2009, 11:16 AM #18
Re: S Traps
09-18-2009, 11:18 AM #19
Re: S Traps
09-18-2009, 02:15 PM #20
09-18-2009, 09:25 PM #21
Re: S Traps
These were in a 4 year old house in an area that does not have any code enforcement.
09-19-2009, 04:41 AM #22
Re: S Traps
If you called in a state plumbing inspector he will make that be corrected. Thats one of the few things that gets me burned up is when a DIYer on a DIY forum asks for help with a plumbing project and you tell them the right way to do it, they reply "Oh I do not need to follow any code since there is no one around to inspect it." We always tell them then, you may get away with it now, but when you go to sell your home, a Home Inspector will catch it then you will have to correct the mistakes then.
