Results 1 to 2 of 2
Thread: wash water drained into sump
09-23-2009, 07:22 PM #1
It is legal to drain your wash water into a open sump pump, I thought wash water would make it grey water ,which I thought had to be covered and vented. thanks for any help
09-24-2009, 08:03 AM #2
Re: wash water drained into sump
In the older homes in Illinois they had the sump pumps, pump into the sanitary sewer system, so they let the laundry water drain into the sump pit. Now most cities, townships, have required the sump pit to discharge outside, which requires the washing machine discharge to stop going into the sump pit. What we do to fix the issue is install a Hydromatic 118 System Hydromatic Pump and discharge the washing machine into it. It does need to be properly vented too.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
