Results 1 to 11 of 11
Thread: PB?
    Sep 2009
    Arnold, MD
    Default PB?
    is this poly , i looked everywhere and didnt see a pic of this kind
    Default Re: PB?
    Yep the gray stuff looks like PB. Not sure about the white stuff. I think the gray flex connectors are supposed to be less of a problem, but I see some gray stuff inside the wall cavity.
    Default Re: PB?
    The off-white stuff with the yellow stripe is CPVC and is no problem. The gray looks like PB but looks to be mostly outside the wall (feeding a DW?). There is just a glimpse of what may be PB running in the wall but I can't tell from the picture.
    william siegel's Avatar
    william siegel Guest
    Default Re: PB?
    Hard to tell from the picture. Check the water heater relief line. I usually always find it there if it is in the house.
    Sep 2009
    Arnold, MD
    Default Re: PB?
    tpr was cpvc. saw mostly cpvc and then one more spot ( bathroom sink)with this same grey piping with plastic white connections .ive never seen white threaded connections on PB so im wondering if it could be pex
    Default Re: PB?
    Quote Originally Posted by biglebowski View Post
    Not PEX, at least no PEX that I have seen. I don't see any CPVC. Looks like polybutylene, but the white plastic connections are alien to me as well.
    Sep 2009
    Arnold, MD
    Default Re: PB?
    well either way i put in my report possible PB. recommend further evaluation by licensed plumber and see PBpipe.com. they had several leaks anyway so I put the plumber on it to see if he knows.
    Orlando, FL
    Default Re: PB?
    The pipe with the yellow stripe is CPVC, FlowGuard Gold.
    The white fittings are Watts Quick Connects.
    Dom.
    Sep 2009
    Arnold, MD
    Default Re: PB?
    Dom.
    I agree with the piping with yellow strip is cpvc but i don't think those white fittings are quite what you have there. notice closer urs dont have those rivets or whatever you call them on the sides and the ones i found have them.
    Mitchell Toelle's Avatar
    Mitchell Toelle Guest
    Default Re: PB?
    Looks like PB inside the wall as well. You appear to be proceeding as you should but you need to stress with your clients that further review be done. Otherwise they will think it is only related to the leaks noted and not the material used. Then you will be in trouble.
    Debra Monte's Avatar
    Debra Monte Guest
    Default Re: PB?
    Most gray plastic pipes will be PB, so it is safe to indicate in your report that there may be some PB supply pipes/fittings along with a little info regarding PB and a recommendation to have a qualified plumber evaluate and replace as necessary.
