Results 1 to 2 of 2
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Waste plumbing connections
    Gents, is this an approved material for waste plumbing connections? It's made out of some type of rubber material.
    Thanks,
    Ryan
    Default Re: Waste plumbing connections
    That looks to be a "Fernco" type fitting, if so then yes they are approved to connect plumbing pipes. However, That does not look like the right size fernco for those pipes.
