Results 1 to 9 of 9
Thread: Copper line erosion?
10-08-2009, 12:07 AM #1
Just did a 2006 McMansion with twin 50 water heaters and circulator pump with the master bath and seldom used jetted tub at the farthest point from the heaters. I suspect the master bath is where the return line for the circulator pump originates.
There was a large amount of sediment and ugly water when I filled the tub but clean and clear everywhere else.
I suspect the circulator pump is causing sediment to collect in a dead end pipe at the tub with the possibility of erosion of the pipes from the circulating hot water.
Any thoughts?
http://www.taco-hvac.com/uploads/FileLibrary/100-41.pdf
Do not oversize the pump or high velocity noise and erosion corrosion of system piping may result.
10-08-2009, 07:28 AM #2
Re: Copper line erosion?
Did the water ever run clear at the master tub?
I assume the house was not occupied.
10-08-2009, 07:47 AM #3
Yep, clear water after the first filling.
The house was occupied but the seller did report that they rarely use the tub.
10-08-2009, 09:06 AM #4
Could be at the end of the line, but with a circulation pump the water is always moving so I would not think that it would have a chance to collect in any place other than the water heaters.
One of those I don't know things we come across from time to time......
10-08-2009, 03:09 PM #5
10-08-2009, 03:12 PM #6
Well, I punted it to a competent plumber with experience in circulating system and a web address for info. My thought was the return line likely taps off the line in the master bath (could not see it - slab foundation) with the tub line below the tee so that the dead line acts like a sediment trap. Once I open the faucet, I just cleaned out the sediment trap.
My issues is that with this 2006 house with occasional tub use I would not expect to find this much sediment.
I did not open the tank drains, but I wonder what they look like?
10-08-2009, 05:02 PM #7
10-08-2009, 05:21 PM #8
Yep, could have been, but galvanized is scarce as hen's teeth around here in anything built in the last 30+ years. Also, I'm doubting that galvanized would rust much in less than three years.
I could see most of the pipe coming out of the slab to the unit but it is possible a galvanized nipple was hiding there somewhere.
10-08-2009, 05:56 PM #9
