10-15-2009, 04:11 AM #1
Height of Gas and Water Shut Off Valves
I looked at a condo yesterday where the main water shut-off valve was 7 feet high and above the water heater and plumbing lines. The gas shut-off valves were a few inches higher and in an equally hard area to get to.
Is there a maximum allowable height for these shut-offs? The unit is 4 years old.
10-15-2009, 05:49 AM #2
Re: Height of Gas and Water Shut Off Valves
Nick - The 2006 IRC says the main water shut-off shall be "accessible".
10-15-2009, 05:53 AM #3
And the 2006 IRC says the gas shut-off valves shall be located, yada yada, "so as to provide access for operation".
10-15-2009, 05:55 AM #4
10-15-2009, 06:13 AM #5
Thanks guys. The valves are accessible but a smaller person will probably need a step stool or a long stick to get to them.
