Thread: Gas Pipe
    Dec 2007
    Holladay, UT
    Default Gas Pipe
    Does the gas pipe in this garage need to be protected from cars etc.?
    http://acloserlookslc.com/
    Default Re: Gas Pipe
    Tom,
    Good question. As it is on the side of the garage and pretty high up, I would think that it is unlikely to be struck by a normal vehicle. However, given your standard issue Hummer and standard issue Hummer driver, a bollard might not be a bad idea.
    Dec 2007
    Holladay, UT
    Thanks Gunnar, pipe isn't as high as it looks. Is haggis as bad as it sounds or looks?
    Exclamation Re: Gas Pipe
    Inadequate pipe support, too.
    Sheep guts and oatmeal boiled in the sheep's stomach. I haven't tried it, and don't really intend to.
    Mesa, Arizona
    It would provide a good handhold for those getting out of a vehicle.
    Jeff Moore AZ Cert#49250
    Level II Thermographer
    http:www.quantumhomeinspections.com
    Dennis Krouse's Avatar
    Dennis Krouse Guest
    Definately a future problem there. If it is going to stick out like that it needs protection from damage. Inadequate support also. Hard to tell from the pic but it looks like a shipping coupling in the line too.
