Results 1 to 9 of 9
    Aug 2009
    Raleigh
    Default 1/2" black pipe tied to 4" drain line
    Anyone know what this might be for... 1/2" polyethylene pipe connected a drain line and then runs up into wall somewhere into the laundry room. I am guessing it might be for a drain pan under the washing machine but without a visible trap, sewer gas may enter the home.
    Atlanta, Georgia
    Default Re: 1/2" black pipe tied to 4" drain line
    Whatever it is for, it is wrong.
    At no time or place is it OK to drill a hole in the side of of a waste line and jam a flexible hose in it. Just plain wrong. Does not matter what the flexible pipe is servicing.
    Georgetown, KY
    AC Coil condensate drain line????
    Aug 2009
    Raleigh
    Quote Originally Posted by Erby Crofutt View Post
    No, it had its own drain line.
    Anthony Alderman's Avatar
    Anthony Alderman Guest
    Dish washer drain??
    Knoxville, TN
    Water softener discharge?
    Eric Spoomonger's Avatar
    Eric Spoomonger Guest
    Quote Originally Posted by Randall Clark View Post
    Anyone know what this might be for... 1/2" polyethylene pipe connected a drain line and then runs up .... but without a visible trap, sewer gas may enter the home.
    It looks like the tubing goes down before it goes up, so if the liquid is just a trickle the dip is working like a trap.
    A half-inch line won't carry enough water to stop a flood. I am thinking it's a trickle discharge of some sort - water softener, protein skimmer on an aquarium, etc.
    Youj also might want to check the attic to see if it continues up to something catching a roof leak.
    M. Slusar's Avatar
    M. Slusar Guest
    I see that type of installation commonly in water softener installations. Flush cycle discharge...
    The installers are NOT plumbers and do NOT know code (or care).
    The simply pipe the discharge from the softener to the nearest waste pipe and typically tie in as shown (drill a hole, shove the tubing in and silicone it.).
    Bad install, illegal install, gonna cause problems down the road.
    Thomas Barker's Avatar
    Thomas Barker Guest
    This is ridiculous to even question a DW drain. Dishwasher drains either have a air gap or a high loop (see inages) that discharges into the kitchen sink drain either through a branch tail piece or a disposal unit.
    Bruce nailed it when he said,
    Get somone to repair the sloppy. illegal work the other guy did. And find out what exactly that hose's draining. Good luck, Tom
