Results 1 to 9 of 9
Thread: Does anyone know what this is?
06-14-2007, 05:18 PM #1
This was found on the side wall near the Jacuzzi. It appears to have a pipe or two running into it. Other than that I don't have a clue what it is. It doesn't twist, turn, or open. It has no valve, button or control of any sort. I really need to figure this out becuase it seemed to have a slight leak.
06-14-2007, 05:35 PM #2
Re: Does anyone know what this is?
C'mon Kevin. You don't know a cup holder when you see one? The leak was obviously spilt beer.
06-14-2007, 06:24 PM #3
Thank's Nick, LOL
06-14-2007, 06:33 PM #4
My guess would be an air break of some type or maybe an air inlet are for the bubble action?
06-15-2007, 12:18 AM #5
But Jerry, Nick already said it was a cup holder, however; the air break thing makes a little since to.
An air break, I think that is what I'll call it.
Saw one on a plane once come to think of it.
Thanks Jerry.
06-15-2007, 04:13 AM #6
If it is the device that regulates the air flow it is called the
Air Admittance Valve: A device that replaces a traditional vent to allow air to enter the pump supply system for the purpose of enhancing the hydro-massage effect of the whirlpool.
Not to be confused with AAV air admittance vent
A portion of it should turn open for more air/bubbles or close for less.
It should not be leaking anything but air, duh
badair http://www.adairinspection.com Garland, TX 75042 TREC # 4563
06-15-2007, 05:20 AM #7
You can get the same effect if you drink a couple of cokes real fast just before you get in the tub.
- Paul Fix
06-15-2007, 06:52 AM #8
Ok, nobody got it. Saw one on a plane, air break, get it?
Oh never mind.
06-15-2007, 11:31 AM #9
could be part of a towel rack b4 new vanity installed. if pipes could have been a heated towel rack.
just my 2 cents
