    Default ID for pipe insulation
    New to me:
    Default Re: ID for pipe insulation
    New to me:
    But not new to that pipe. I have seen it a number of times. It is a foam product that has crumbled and is no longer serving its intended purpose.
    The 2nd photo looks to me to be some old asbestos or other woven fabric - frankly the detail is tough to make out but your thumb nail is amazingly clear (might want to talk to your doc about the nail fungus).
    Anyway, did you come across any source to plug in? looks like some very old insulated fabric (noted yellow thread) heat tape with some corrosion. Might be unexpanded vermiculite.
    Thomas Barker's Avatar
    Thomas Barker Guest
    You might want to remove the old foamy stuff and Armoflex (see image ) your pipes. Good luck, Tom
    Stacey Van Houtan's Avatar
    Stacey Van Houtan Guest
    Looks like a old armstrong product, Cork and PACM (Asbestoes)
    used on chill water and domestic water pipes in past
