Results 1 to 15 of 15
Thread: Loose Toilet?
11-11-2009, 04:21 PM #1
Loose Toilet?
What constitutes a Loose Toilet?
11-11-2009, 04:23 PM #2
11-11-2009, 05:15 PM #3
Re: Loose Toilet?
Either the between your knees or just nudge it with your knee. If it is loose it will move. If it moves in the slightest it is loose. There is no close to moving. It's loose or it's not. The wax ring seal is now broken if you can move it at all. You cannot just tighten the toilet back down and it's all better. The wax ring does not swell back up. It might not be leaking water but it could be leaking gas.
11-11-2009, 05:31 PM #4
Re: Loose Toilet?
11-11-2009, 05:37 PM #5
11-11-2009, 06:41 PM #6
Re: Loose Toilet?
I just give them a swift kick with the shoe, if it moves it is loose.
Many times (at least I did) you will find them "move" be not be "loose" ... i.e., the toilet itself is securely attached to the floor flange (not "loose") but the floor flange is not securely attached to the floor (allowing the toilet to "move") - this means the toilet is "loose".
11-11-2009, 06:50 PM #7
Re: Loose Toilet?
Wow - A Toilet that passes gas..........lol
I usually straddle the bowl between my knees and try to rock it!
11-11-2009, 07:36 PM #8
Re: Loose Toilet?
I'm with Scott. Well, I don't really bear-hug the things, but I do use my hands. Hey, that's what an immune system is for! Use it or lose it!
11-12-2009, 12:05 PM #9
11-12-2009, 12:15 PM #10
Re: Loose Toilet?
11-12-2009, 12:54 PM #11
11-12-2009, 06:34 PM #12
Re: Loose Toilet?
11-12-2009, 07:03 PM #13
Re: Loose Toilet?
Jim, an immune system won't defend against body lice!
11-13-2009, 09:04 AM #14
Re: Loose Toilet?
I straddle the toilet with my legs, (standing up of course) and wiggle the toilet an the tank. I call this the toilet dance. If it moves I write it up as loose.
11-13-2009, 10:22 AM #15
Re: Loose Toilet?
I agree with Joe and Dave.
