Results 1 to 3 of 3
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Correct waste plumbing material
    As far as I know this is not an approved waste plumbing material but I wanted to double check with everyone.
    Thanks,
    Ryan
    Default Re: Correct waste plumbing material
    You are so correct. Drain pipes must have smooth interiors.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Second the motion.
