    Sep 2009
    Twin Cities, Minnesota
    Default Washing machine pan
    Is there code that requires washing machines on the second floor (or not in the basement near the basement drain) be in a pan with a drain, or is it just good practice?
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    David Bell's Avatar
    David Bell Guest
    Default Re: Washing machine pan
    As far as I know only water heaters are required to be panned and drained to a basement or other space where it will be noticed but not do damage.
    Nov 2009
    St Paul, MN
    I'm not sure if it's code but I always suggest it if the room below it is finished.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    A.D. Miller's Avatar
    A.D. Miller Guest
    To my knowledge there is no national model code requirement. That said, many local authorities require these pans. Most require the pans to be drained to the DWV system.
    Jul 2007
    Chicago
    It is not code but is recommend .
    There may not be a drain , but the pan will at least hold spillage.
    Sep 2009
    Thanks for all the responses! Very helpful.
    -Jon
    Nov 2009
    St Paul, MN
    Jon, Here we normally see them drained to the basement or slab floor drain, with an air gap between pipe and floor drain.
    Sep 2009
    Ken -- thanks! I was just inspecting a townhome in Bloomington yesterday that had been remodeled and the new washer and dryer were in a closet on the second floor.
    But yes - I normally find them in the basement.
    -Jon
