Thread: PEX Stub Out
01-26-2010, 08:59 AM #1
PEX Stub Out
This is the firs time I've seen PEX run through the drywall and connected directly through a fixture. Is a copper or brass stub out required?
01-26-2010, 09:28 AM #2
Re: PEX Stub Out
no they can connect directly to the fixture if they want too.
01-26-2010, 09:32 AM #3
Re: PEX Stub Out
"This is the firs time I've seen PEX run through the drywall and connected directly through a fixture. Is a copper or brass stub out required?"
No
"no they can connect directly to the fixture if they want too."
Well, kinda. Needs to connect to shutoff first, in most cases.
01-26-2010, 09:49 AM #4
Re: PEX Stub Out
My concerns are:
(1) The bending radius in a 2X4 wall
(2) The necessity to cut the PEX when the shut-off valve is required to be replaced at some time in the future.
01-26-2010, 10:13 AM #5
Re: PEX Stub Out
My concerns are:
P2904.3 Polyethylene plastic piping installation
...For bends, the installed radius of pipediameters of any fitting or valve....
curvature shall be greater than 30 pipe diameters or the coil
radius when bending with the coil. Coiled pipe shall not be bent
beyond straight. Bends shall not be permitted within 10 pipe
Looks like it is coming straight out of the wall, likely to have an Ell in the line.
No more of a concern than with CPVC
Also, the valve can be replaced without cutting the pipe.
01-26-2010, 11:03 AM #6
Re: PEX Stub Out
They probably used a 90 in the wall to turn out for the shut-off valve.
01-26-2010, 06:17 PM #7
Re: PEX Stub Out
All the time, every time, around here. In fact it has been years since I have seen a copper or brass stub out in new construction, I have not heard of any problems associated with doing this.
This is the way it is done every time I see them, which is almost daily.
