Results 1 to 28 of 28
Thread: Check out this trap!!
01-31-2010, 11:29 AM #1
Never seen a trap like this before...what shall we name it?
Chuck
01-31-2010, 11:44 AM #2
01-31-2010, 11:46 AM #3
Re: Check out this trap!!
That would be one of those new style b-traps (or d-trap, depending on which side you look at it).
01-31-2010, 01:07 PM #4
Trombone trap
01-31-2010, 01:28 PM #5
Not a trap, not an elbow. It's a C-bow.
That's one of those designer glass sinks that has built-in overflow. It just overflows over the sides of the bowl!
02-01-2010, 08:16 AM #6
Just goes to show you can't make anything foolproof, the idiots are far to creative.
02-01-2010, 08:34 AM #7
Sorry I can't comment on the trap, my brain is still trying to recover from the wallpaper.
02-01-2010, 08:45 AM #8
I don't know, when you're laying on your back under that sink and dizzy from looking at that wallpaper, it kinda looks like a P-trap.
02-01-2010, 08:50 AM #9
One more question, Is this no-overflow-channel sink allowed? How can we report for home inspection.
02-01-2010, 09:05 AM #10
"Sidely Whiplash".
02-01-2010, 10:20 AM #11
Does the code require overflow channels in sinks? I was recently looking at the study materials for a plumbing license and it didn't mention one and several sinks I've seen don't have them. Could it be a local requirement?
In the sinks I have seen with them they are usually bacteria and mold culture labs. I can't think of a better place to grow mold than a dark, warm, consistently moist cavity like an overflow channel.
I have to say, given the choice between a non-trap like this and the fancy bottle traps they usually sell with these basins, I'd rather the DIY crowd used the bottle trap.
02-01-2010, 10:25 AM #12
"One more question, Is this no-overflow-channel sink allowed? How can we report for home inspection."
No requirement to have an overflow.
02-01-2010, 10:58 AM #13
02-01-2010, 05:20 PM #14
We know why you fly: because the bus is too expensive and the railroad has a dress code...
www.atozinspector.com
02-01-2010, 06:35 PM #15
Kitchen sinks don't have overflows.
Laundry wash sinks don't have overflows.
02-01-2010, 06:54 PM #16
Not only no requirement for overflows in sinks but I have not seen a sink with an overflow which could keep up with a full water flow ... meaning the overflow is basically useless ... I say "basically useless" recognizing that if one were to put too much water in the bowl, have the water off, and then put your hands into the water, the water level will rise and the overflow would likely handle that.
02-01-2010, 09:18 PM #17
Nevertheless, an overflow will help and if the taps are not on full, there will be minimal or no water spillage.
A typical double kitchen sink has built-in overflow protection, the other side.
It takes a lot of water to overfill a laundry tub.
By coincidence, I had a glass bowl sink this PM. Turned the water on full with the stopper down, and had a 3/4 full sink in less than a minute. That is too short of a safety margin in my mind. Ok, I don't like these sinks.
02-01-2010, 09:26 PM #18
"I have to say, given the choice between a non-trap like this and the fancy bottle traps they usually sell with these basins, I'd rather the DIY crowd used the bottle trap."
I've seen the bottle traps used on pedistal sinks, but not on anything else.
02-03-2010, 11:52 AM #19
It looks like an improperly installed trap.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
02-03-2010, 07:36 PM #20
02-04-2010, 05:38 AM #21
Looks like a BOOBY trap,,just can't stop lookin at it.
02-04-2010, 07:29 AM #22
02-05-2010, 04:45 AM #23
Homeowner is probably wondering why he has constant problem of sewer odor in room. (Hope he has a good exhaust fan!)
Obviously does not know the purpose of traps.
03-22-2010, 07:51 PM #24
There double trapped, and then there's double trapped. Both from this afternoon's job:
03-22-2010, 08:14 PM #25
03-22-2010, 08:49 PM #26
03-23-2010, 05:32 AM #27
03-23-2010, 09:48 AM #28
It was a bear of an inspection - 143 pictures of the usual &()%^#%$ REO stuff - but nothing else quite came up to the level of the "trombone trap" or the forming technique for that pier, probably the next best was the collapsing service mast that brought the service drop down onto the roof:
